There is a way you could use regular gas pipe. Get a piece of pipe a little longer than you want that is threaded on both ends. Get some dry sand and two caps for the threaded pipe. Put the cap on one end. Stand the pipe on its end and put in some sand, tap the cap on the ground to pack the sand down. Keep doing this until the pipe is full, then add a little extra to the top and screw the other cap on. You now have to heat the pipe in the area where you want to bend it, an oxy acetlyene rig is probably necessary. Once the pipe is hot bend it around another larger diameter pipe to get the desired radius. Once cool remove the caps and clean out the pipe, cut off then end you dont want. Install it and burn the tires off that rascal!!!
