i have a old 5.5 genuine Honda i got from a lawnmower place, traded for it with a $80 chain saw i got running from the dump. ive had it for a wile. i cleaned the carb and i got it running good. the one issue is the old pressure washer pump was stuck on the crank, he soon cut it and its about 1.2 inches long now wich is NOT long enuf for a clutch. i want to use it on a monster truck go-kart im building with a lawn mower trans axle. i want to know IF a gx200 CRANK SHAFT will work in this GX160. and what else is compatible? thanks MM.
