I would only be guessing, that is where your ring gap is on the piston.
To me its in kind of a bad spot , ya know, it is where the exhaust valve is an all.
But, no damage to the wall and looks to be no damage to the piston.
However, you can't see if its causing any damage at the ring gap / slot area.
If you want to be sure, I'd pull the side cover, remove the piston and check.
if all is good, put your gap away from the valves.
