Hello, I have one of those on the shelf as well. Came with the 1" crank and std. side cover. Points style ignition with a heavy cast iron flywheel with the plastic air fins. The block will take a std. 3/4 crank and the aluminum flywheel. I ditched the 1" crank, heavy flywheel, side cover and recoil cover. Swapped them over to the 3/4 crank, with ball bearing side cover, al. flywheel and older style recoil cover.
Regards,
Joe51
