Ok, fair enough, I'll try again sir.
"Rod angle - that is a large influence on the torque curve - more rod angle, more low end torque. Longer rod, less rod angle, higher revving engine, less low end torque."
Engines are built for a purpose. Drag engine, track engine, time trials engine, etc. For a drag engine, it would by definition be tuned (not air/fuel, but timming, compression, etc) differently than a circle track car engine.
You're out there running drags, with whatever drive train setup you choose. I just stated properties of rod angle. Which works best for your application would take some testing. Clutch stall, or TAV tune and such. I don't know. One thing we all know is that the engine that runs best on the dyno, isn't always the one that runs best on the track.
What I ran were nitro burning two strokes in sprint racing hydroplanes on an oval course. For that setup, boats had a prop with no clutch or tranny, the shorter rod engines worked better as they had more low end torque and could pull a larger prop with more blade area which cornered better and accelerated out of the corners real well.
I can't tell ya any more than that - cuz I don't have a drag mini-bike, I run a trail bike. The racing karts I run are high reving engines with lower rod angle.
