I bought a 6.5hp carroll stream electric start engine with a built in charging coil.
6.5HP Gas Engine With Electric Start
This engine has both electric and a recoil start, I am thinking about not using battery and just use the pull start.
My goal is to put a ‘few’ lights on my doodlebug and have it powered straight from the engine without the battery. Since this engine has a built in charging coil, (12volts 3amp) I think I should be able to hook up lights straight to the motor just like the old mopeds.
If I put a headlight (0.5amp) straight into the 3amp motor, do I need a rectifier or a regulator? If so, where do I buy one and how do I install it?
thx
thx
