Looking good, I like the clutch cover, are you going to fill in where the drum brake bolt hole is?, if so, the easiest way I have found to fill holes with out the weld falling through is to put a piece of fire brick or ceramic tile under the hole and just spot it a few times with the MIG welder. Unfortunately mines on hold due to work but I look forward to your progress, keep up the good work!.
