Since I've become more educated on mini bike vintages, I've really come to appreciate this pretty rare Lil' Indian Sabre frame I picked up as my first mini bike earlier this year. I've decided to strip her down and send her off to sandblast and powdercoat. Here she is all stripped and ready to go.
Here is the beat up old briggs that was originally on her. I'd really like to get a gleaming clean engine to put on this frame once it's all done, but I'll just clean this one up as best as possible for now.
This engine is too small (almost positive it's a 3hp) to get any decent performance running a straight gear ratio. I plan on using a two speed clutch set-up. I'll have a clutch with two drive sprockets on the engine output shaft. Two chains will be coming from that clutch to the jackshaft. One chain will be on a 18 tooth sprocket, the other will be on a second clutch with 12 teeth. Then I'll have a 12 tooth sprocket going from the jackshaft to the 60 tooth sprocket on the rear wheel (6" rim). This will give me a final drive ratio of 7.5 in first gear and when the RPM's of the jackshaft hit 2000 to 2200 RPM, the second clutch should kick in providing a final drive ratio of 5 for second gear. It really doesn't matter too much because this bike will be ridden on special occasions only by me only.:thefinger:
