Hey guys got a Question for you, We have a Bird Thunderbird with a HS40 on it. It runs fine but while riding on a bumpy surface or if it hits a bump the choke lever vibrates or gets nocked into the on position, then the engine stalls out. The spring that goes in the notch is in tact but the whole lever seems loose on the rivit.
My question is ..... Is there any way to tighten the lever or do something to it to keep this from happening. Most of you guys have been doing this a lot longer than I have so I figured you may have seen this before and have some good suggestions.
Thanks
Thanks
