It's true, the fiber washer that comes with the maxtorque clutch (keep in mind, mine is not an oem doodlebug clutch, it's a genuine maxtorque ss clutch bored out from 5/8 to 16mm), is very thin. When I took my clutch apart, I noticed that there was quite a bit of space between the bushing and the shaft. My thinking was this. On ktm mini engines, they use a spring washer stack to pre-load the clutch for better balance and smoother engagement. So I thought the same principle might apply to our clutches with a thick enough fiber washer to occupy that space between the bushing and the shaft. I don't know if it really helped all that much, but it's not hurting anything and the fiber washer isn't disintegrating, so.... As far as lube goes, I don't know how hot motor oil can get before it evaporates, but the grease I use has a dropping point of over 500 fahrenheit, and I've had much better results with it. I know taking the clutch apart to grease it every couple weeks seems like a hassle to some, but to me it's worth it for the smooth operation of my clutch. It's pretty easy to remove the snap ring on the end of the shaft, pull the drum off, put the grease where I want it and put it back together. Easy-peasy. I will probably pick up some brake cleaner next week and spray it inside the drum before I re-grease again. Just to make sure grease isn't getting inside the drum or on the shoes.
