Ok so i was mounting my new clone onto cjtmini's mounting plate. I put alittle bit of loctite on all of the bolts that mount the engine to the plate, and the plate to the frame. I got a phone call and got sidetracked. When i was done i started working on mounting the clutch and little bits here and there. When i went to tighten the chain and move the engine forward, i couldnt tighten the bolts. The loctite has set and locked the nut onto the bolt. When i tighten it the bolt just spins. I cant reach the head of the bolt to hold it in place because it is hidden under the engine.(anyone with knowledge of cjtmins plate knows what i mean). So basically i cant take my engine off the plate and i cant take the plate off, or even tighten the nuts, to the frame. WHAT SHOULD I DO?! i think im going to have to get a nut cutter and start over. I cant believe i let the loctite set. Im kicking myself. I cant ride it STILL!!! Please help me. What are my options? Nut cutter, heat? solvent? DAMN!
