OK, took my bowl off to clean my e-tube and jet, put the bowl back on (in the dark) and the bowl was leaking, so.... instead of pulling it off and checking to make sure the gasket was aligned properly, I tried just tightening the bottom bolt an extra 1/4 turn. Long story short, each time I have taken the bowl off (to change jet or e-tube) or to clean, the threads have gotten worse and worse. Now the threads are just gone, not on the bolt, those are fine, but the threads on the bottom of the carb.
I tried using my tap-n-die set to clean up the threads, but there is just not enough there to hold.
Any ideas, or products which would allow me to re-thread under there? I thought about drilling it out and going up a size for the bottom bolt, but the tube just isn't that thick or wide, not sure I could go up a size.
Anybody else done this? How can I fix it without buying a new carb?
