Great work so far.
The only suggestion I have is regarding the swing arm pivot. the swing arm pivot bolts will elongate(wear) the holes in the frame they pivot thru unless you surround them with a bushing they can pivot on. Or you can change the pivot set up by removing the nuts which are in the swing itself, and replacing them with bushings and use one long bolt from one side of the frame to the other as the pivot.
Keep up the good work. I'm in Chicago and would look forward to heading down Old 66 to meet you someday(after the weather breaks). I've got some fabrication needs of my own.
P.S. If you need tecumseh engines or parts, let me know, I got plenty
