Depends on how you drive it.
I am not familiar with that carb but if its made for the Yahmaha its likely a much closer fit to a clone than a carb from some other aplication that may not flow fuel in a way that makes a clone easy to tune and run.
The cam might be more reilaible with some valve train upgrades.
But these are also dependent on how hard you push the engine, the important thing is to use the recomended springs and lash caps on both valves. If you have access to Honda parts these will be stronger and last longer than clone.
The TAV will allow you to drive it around and keep the rpm down.
This may or may not work well for you depending on what you expect.
As a torque sencing system it will try and drive your engine RPM down in respons to light loading.
This is good in many respects but it can make the top end a little lay.
I don't know if this is just my bad luck but I bought some PIX belts because I was told they were the same as OEM comet belts.
Well the PIX belts don't seem to be made from as hard a compound as a belt marked comet.
I seem to be the only person experiencing this problem so it might be an isolated case.
Just to be safe though don't cheap out, get at least 1 comet belt and a spare because an engine that makes more power can eat up a belt. But a belt can last a very long time if you are careful.
