Hey Myjunk, That engine is correct as Tecumseh did away with the last of the old style motors around 1974 the shroud has been replaced but since the pull start sits in the right position, if you paint/ dump the primer decal it it will look like it should from the Rupp factory. The stamped numbers on the shroud probably wont match but not too much you can do about that short of stamping your own in.
The air cleaner is rong as well and in the wrong position, but again another easy fix:thumbsup:
I'm curious about your tires on it. Mine are not "rupp trials" made by IRC Japan as usually seen. they are just stamped Trials and actually 3.00 x12" rather than the usual 3.50 x12" They are also an american made tire, but no manufacturer stanp that I see. They look very much original though to the bike. I'm also trying to figure out about the handle grips and what correct footpegs should be. Mine has waffle grips, looking around it looks like other do too. No pegs on mine, and looks like alot of them are missing on others as well so I wonder if they went to something else there not as stout as what they used in previous years.
The last year bikes I would imagine were now having to share with the New line up MX bikes Rupp was focusing on.
Mines rusty/crusty. I have it on the bench right now just got it sparking again, carb is soaking and I'm getting ready to fire it up and blow some rust out the muff!
