I just can't resist these cheap flatslide copies. First I got the OKO copy then I saw this one a Nibbi which is similar but the other ones as well as the mikuni TM come in either 24 or 28mm. This one was a 26mm. Just got it late today so I have not taken it apart yet but it is very similar to the OKO with the exception that the slide looks a lot better. I will take some pics disassembled tomorrow if I can. I have a built hemi predator that has the 24mm OKO on it which I have not run yet but I will set it up on a stand to test both carbs. I will also put this one on the flowbench to see what it flows. The 24mm OKO flows around 96CFM at 28"H2o so I would expect this one to be slightly north of 100. Now that I can cut and install the 32mm valves I wanted to try a slightly bigger carb and a straight manifold.
