"Is there anything I should know before I buy one?"
Yeah, expect to be disappointed with the mini bike's power right off the bat. There's a few things you can do to the DB30's stock 2.8 engine and the bike itself to improve it's performance:
1.) Change the oil.
2.) Pump up the air pressure in the rear tire (20 psi is what most use as rule of thumb).
3.) Drill out the muffler. Two 3/8" holes through the exhaust outlet in the muffler. Be a good idea to remove the muffler first.
4.) Back out (or remove) the throttle stop screw.
5.) Experiment with the choke lever. Some DB30's run better with the choke somewhere between the on and off positions.
6.) Use high test (or "premium") gas.
If you plan on using the stock 2.8 hp engine for a while, ProMod makes a jackshaft kit that does great for take off and increases top speed as well. The price is $119 for the jackshaft kit. Be sure to mention that you're a OldMiniBikes.com member and get a discount price for the kit.
Baja Doodlebug,Dirtbug and Blitz Bolt on Jackshaft Kit
"Why do you call it a "Dirt Bug"?"
On the front and rear fenders of the DB30 mini bikes, there's a decal with the bike's name. The yellow bike is a "Dirt Bug", the red bike is a "Doodle Bug", etcetera.
Jimmy S.
