C
After further review I've moved this post to where it should have been in the first place. Sorry, I'm pretty new to this forum stuff. It was hotter than hades today in western Tennessee but I spent a couple of hours on the bike. I checked the oil and it was full and gold so I didn't change it. The gas was old, I could only tell when I drained it and put fresh in. I pulled the float bowel and it was rusty of course so I cleaned it out with a nylon pad and soap and dried it and put it back on. I pulled the spark plug and it didn't look so good so I cleaned it up with an old tooth brush and a very little bit of fresh gas and after it dried out I hooked up the wire and grounded the plug on the side of the motor and pulled the starter rope and I got a real nice blue spark. I pulled the choke and tugged on the rope again in after about 5 pulls the engine started and ran just fine. Needless to say I was pretty happy about that. I then dug around and found a couple of old Harley linkert parts, a spring for the throttle return and a pivot for the throttle cable (I had to cut the pivot shaft down on the lathe a bit) and rigged up a passable throttle system. Mindful that the governor was unhooked I cranked it up again and took off down the block for my first ride. Everything seems to be fine, it sounds like I have a rattle in the front wheel so I will take that apart this week to see what it looks like. Other than being so hot it was a good day.
Here's the picture of the wrong air cleaner and muffler
