Converted my trail use newer style doodlebug to the older flat seat. If you have a welder and a toarch or map gas/propane toarch its not hard takes an hour.
The bent seat looks cool but hurt my ass on long rides.
Cut the weld at the rear frame mountswhere they go verticle at the back hoop, if you heat the frame at the bend where it goes down lift up and set it level.
Now cut the back section off and remove the bends,weld the 2 tubes back together and the back hoop back on the uprites. Done.
