OldMiniBikes Warehouse steel sprockets
I am not too sure as to whether you could get one of the OldMiniBikes steel universal industry mounting hole sprocket to interface with the DB30 hub without some modification (8 hole mounting pattern rather than the DB30's 6 hole).
The size of sprocket you can use will also be dictated by the size of chain your converter will accept.
However, I do know that the OldMiniBikes doodlebug sprocket adapter works great and fits the standard go cart split sprocket which are available in many chain sizes and tooth counts. From that I would surmise that the OldMiniBikes sprocket adapter would be your best bet.
