This is what I got done today. As I am retired there is no reason to do anything that does not please me to do. The first pic shows the megaphone complete. A stay, bolted to the head, was added to forestall failure caused by the long megaphone flapping in the breeze. The next two photos are about the rear wheel chain adjusters. Slots, to fit the rear portion of the axle tabs, were cut in a couple of pieces of rectangular key stock. A bar could have been welded across the opening for the axle but that would hace required that the axle be inserted through the wheel bearing assembly to put the rear tire in the frame. This method takes a little more time to build but makes wheel removal easier. The last photo shows the split clamp , that secures the velocity stack to the carb, trial mounted. Today I acquired some aluminum parts at a truck repair shop. They are a pair of 3-1/2" dia. flanged "heads" made from aluminum. They are really block off plugs for a certain size of rubber tube. Also a hunk of 3-1/2" dia. aluminum tube. Told the guy that he had to give them for free or I'd spread bad storys about him. So most everthing is on hand to make a fuel tank.
