Oversized valves What are the largest valves that can be installed in an Animal or WF head? Thanks
yalipito Member Aug 3, 2015 #1 Aug 3, 2015 #1 Oversized valves What are the largest valves that can be installed in an Animal or WF head? Thanks
125ccCrazy Well-Known Member Aug 3, 2015 #2 Aug 3, 2015 #2 28/32 fit good, not sure if you could go bigger without a ton of work or why larger than that would be needed..
yalipito Member Aug 3, 2015 #3 Aug 3, 2015 #3 125ccCrazy said: 28/32 fit good, not sure if you could go bigger without a ton of work or why larger than that would be needed.. Click to expand... Is there enough room to unshroud the valves and get the head gasket to seal afterwards?
125ccCrazy Well-Known Member Aug 4, 2015 #4 Aug 4, 2015 #4 with 28/32 there is, I have a set in my WF and had a set in an engine I sold a while back.
yalipito Member Aug 18, 2015 #5 Aug 18, 2015 #5 125ccCrazy said: with 28/32 there is, I have a set in my WF and had a set in an engine I sold a while back. Click to expand... How was the power in these engines? What cam are you using?
125ccCrazy Well-Known Member Aug 19, 2015 #6 Aug 19, 2015 #6 havent ran my wf yet and sold the other engine last year but the buyer said it was a monster... running 356 cams, 28mm Mikuni, pvl ign,etc.
yalipito Member Aug 19, 2015 #7 Aug 19, 2015 #7 125ccCrazy said: havent ran my wf yet and sold the other engine last year but the buyer said it was a monster... running 356 cams, 28mm Mikuni, pvl ign,etc. Click to expand... Do you advance your timing beyond 30deg? Gas or alky? My parts are somewhat similar (cam is ANmod01). Not currently using the mikuni though.
