I am repainting a 1965 Craftsman Tractor and need some input. I completely disassembled the entire tractor over the summer and already began to completely strip the paint off of some parts with a Norton Rapid Strip Wheel, throughly clean and degrease every part using Denatured Alcohol and on some pieces Lacquer Thinner, then I painted using this process
1.) Prime using Rustoleum Grey Automotive Primer, sand lightly then apply another coat of primer.
2.) Color Coat using Rustoleum Black Night Metallic with Metal Flake, 1 lighter and then 1 wet coat.
3.) Clear Coat using Rustoleum Acrylic Lacquer, applied more coats of that on larger more used and more visible pieces.
The final results of the already painted pieces, I think are great but am afraid because of the fact that spray can paint is just temporary and if a crack or chip in the paint occurs will rust just eat away at the entire piece. I want this to look almost brand new but I also want to use it without it rusting up after a few months.
Thanks, any help or tips would be great
Nick S.
Nick S.
