Well, I spent most of the weekend connecting the dots, and now this thing is starting to look like something mobile.
I put everything together to check out the bugs and do some tweaking. I tacked on some fork stops on the neck tube, and the tank mounting brackets.
I started on the brake pedal and noticed a problem with the linkage ratio being long on the travel, so I made up a shorter brake actuator arm, which lead to another issue of the rod interfering with a nut on the bottom shock bolt. So I had to eliminate the nut and weld an insert in the shock mount tab and just thread it ...like I did to the top. I don't know why I didn't think of that in the first place.
Right now the brake pedal has about 2" of travel till it bottoms, but that will probably change once I actually road test it and adjust.
The next thing I want to tackle is a center stand. I've never seen a Rupp close up to see what exactly keeps it in place in the up position. I've thought using a broom handle clip, mounted to the stand that snap over the foot peg bar to keep it up. Anybody else have a solution?
