Calculation for Pipe Diameter....
Pipe Cross Sectional Area = (Displacement x RPM) / 88,200
1" Pipe with 0.065 wall thickness has ID of 0.87"
CSA of that pipe is 3.14 x r^2
r= 0.87"/2
r =0.435"
CSA= 3.14 x 0.435" x 0.435"
CSA = 0.59 sq inches
Displacement of 212cc = 12.94 cubic inches
CSA = (Displacement x RPM) / 88,200
For a 1" (0.065 wall) pipe...
0.59 = (12.94 x RPM) / 88,200
52,432 = (12. 94 x RPM)
RPM = 54,432 / 12.94
RPM = 4,052
So a 1" Pipe with 0.065" wall thickness is tuned for 4,052 RPM.
A predator with basic modifications might make peak torque at 2300 RPM and peak HP at 4700 RPM.
Using this formula to calculate the CSA of a pipe tuned for peak torque at 2300 RPM gives 0.34 sq inches.
0.34 = 3.14 x r^2
r^2 = 0.108
r= 0.33"
ID = 0.66"
So a pipe with Inner Diameter of 0.66" is tuned for RPMs around peak tourqe (2300 RPMs)
7/8" 0.109" wall thickness (found it online)
For 3900 RPM I'd use 1" 0.065" wall tubing.
All just theoretical of course. I don't have a dyno to test on, nor do I have multiple pipes to experiment with.
Without getting into wave tuning and Exhaust valve opening, shorter pipes fatten the HP curve post peak HP and longer pipes fatten the curve pre peak HP. But it is all just called exhaust "THEORY" right?
Also limited by what is tubing is available. 1" Pipe is good because it it will fall between peak torque and peak HP on most engines. For an engine governed to 3600 RPM I might use 1" 0.083" wall thick pipe.
