got started on porting the combustion chamber area, still need to clean up around the valves and polish her up. I will post more pics and updates as i go. The ports themselves will be fun :/ How does JB Weld hold up to gasoline?
my dremel is a single speed, was in a hurry when i bought it, a variable would be infinitely better. those little flat sandpaper discs are BOMB for little detail spots like around the valves. I was able to unshroud them quite well imo, just cut out the step and blended a radius leading to the steel seat area. i nicked the seat a few times due to misjudgement of light when the sun got in my eyes not too bad hopefully it will come out when i grind the valves.
I dinked the HG area in a place or two as well, im gonna dab some JB on there and glass deck it flat when im done. I think im gonna leave the head alone entirely except for decking.
If i dick up this block too bad im gonna search for a steel bore block. the flywheel side bushing area for the crank isnt even a bronze insert on this one although the cover has a bearing in it. Anyone know if they sell a bronze bearing sleeve for the flywheel side of the block?
