Hello, today I purchased a manco go Kart with a preadator engine that did not run. It seems as if the kart had sat outside for sometime and water got to the engine. The first thing i did was replace the pull start cord and assembly. The engine would not turn over. I was able to free up the engine by putting a ratchet over the flywheel nut and it broke free. Then I replaced the air box and exhaust with spares I had from previous projects. I also removed the spark plug and it was corroded with rust. I replaced that. I also drained out the gas tank and oil. The oil was mostly water. I replace the oil and gas with new oil and gas. I tried to run the engine, but no avail. My next step is to replace the carburetor as I ordered a brand new one from Amazon for 10 dollars. If anyone has any other suggestions to get this engine running it would be greatly appreciated.
Thanks, Dean
Thanks, Dean
