Predator 212 hemi rockers
Thank you, what cam do you recommend using with the Brad Hill 1.2? I should add I am supercharging the engine with an AMR300 (running 10-15psi) I will start the psi off at about 6, and work my way up hopefully without injury to the engine. I would like to run as much lift as possible to compinsate for the low gearing of the bike.
no !!! brad hill has 1.2 hemi rockers though
Thank you, what cam do you recommend using with the Brad Hill 1.2? I should add I am supercharging the engine with an AMR300 (running 10-15psi) I will start the psi off at about 6, and work my way up hopefully without injury to the engine. I would like to run as much lift as possible to compinsate for the low gearing of the bike. I believe I would want more valve overlap? I am not 100% sure.
trinik7597
Contact Brad hill performance... he is a great guy .... tell him what your plans are . He will be able to make a better recommendation than I could .. he has a ton of experience with the hemi heads
