Predator 212 Hemi Ticking noise
Have a predator 212 hemi mild build bsp3 cam intake and header it makes a weird ticking noise idling, I know it's not a knock when I opened it up the rod was tight like it should be motor is basically new it runs very healthy and it did make the noise when I first bought it. I'm thinking valve lash? Also wanted to know if there is an app for this site. Thanks
Was it built when you bought it or was it stock? Lash is easy enough to check if it was stock or modded.
I've read that when modded, on some when you change the valve springs they can hit each other unless the head is machined.
