Anything that can be moved out of adjustment can be marked with a sharpie for future reassembly reference points.
Not to join in the pissing contest here, but that statement is incorrect. I've been called out on this before; being "OCD" when it comes to putting these motors together, but there is a big difference between a Briggs and Stratton magnetron ignition (or other magnet-driven solid state timing system) and the points and timing of a Tecumseh. You aren't timing the latter with a sharpie....especially since 9 times out of 10, the previous guy did exactly that, and it runs like shit, and shears the key every once in awhile.
Setting timing on a Tec is more tedious (not hard) than setting valve clearance on a OHV.
As far as the original question, the comparison between a Briggs 3 and a OHV 6.5 HP is apples and oranges. The 212 will vibrate more, but then it has twice the power.
The question is, what application are you referring to? A vintage, restored mini bike or kart where you want it to be correct? Or just a knock about rider quality fun machine?
I just finished up a Tecumseh H35 and put it back on the original bike. Before that, I had a 5.5 clone on it, just for testing the chassis. The H35 pulls just as good as the 5.5. Way less vibration, but admittedly slower off the line. Slightly. A 212 would have been a way better engine, and probably would make a great rider out of that particular bike.
Hard to beat 99 bucks. But so far, I've refrained from putting a clone on a vintage mini bike. I wouldn't hesitate to build one up for a drag project however.
