one more thing i had to do today before i start to take it all apart to repaint the bike and thats was to build a header pipe:hack::weld:
started with a header flange by using a over size washer that was about 1/8+ thick with a 1inch #dem hole.
i wanted to baffle noise level down little with the straight pipe set up by using some flat washers. first thing i had to do was cut a slot into them and then bend them apart. i use a 3/8 bolt for my jeg to weld my washers together.
after welding washers together i place them inside the pipe with couple pre-drilled holes in the pipe so i could weld the baffle unit in place.
after i finish the exhaust i will go back and grind the weld marks off:grind:
(finish mock-up exhaust). i added a hanger just below the seat couple inch's or so and also made a turn out tail pipe on the end of the exhaust:thumbsup:
i will finish the pipe with a gray hi temp header pipe paint that will not discolor on me...........
