My rupp roadster has no cable or governor linkages and I am trying to figure out how it hooks up...It looks like the cable goes down to the little arm below but it seems like the cable would be on quite a severe angle unless the arm was pulled up pretty close to where the cable casing is attached to the engine....When I pull the arm up close so that it is more inline with the cable it has pretty extreme spring pressure ...The spring appears to be hooked up properly?
