Trial and error are your best bet here. The 3 holes allow for different settings of the wound spring tension. The lighter the tension the faster it will shift out into high gear. For a light weight rider on flat ground that would have the highest top speed. For a heavy rider, the light setting may now let it shift as high for top speed. It may try to hold it at a lower gear ratio.
Try each hole and determine which one works best for your riding style and conditions. If you climb a lot of hills then the tighter spring setting would probably work best. Flat paved surface riding ???
Experiment with it
Danford1
Experiment with it
Danford1
