Here's how the second one will be. The parts are just loosely stuck together to give me an idea what I'm starting with. It's hard to imagine what it will look like with all these mismatched parts, but it will be cherry red with lots of gold pearl in the clearcoat. I'm getting a new seat and shocks. The seat will be the same as this one, but red metalfake on the top.The engine, I bought minus the recoil start. I threw on an old nasty one I use on 5hp Briggs engines when I'm working on them. It's a 5hp Briggs. The head has been shaved, ports cleaned up, valve work of some sort, I added a 1" stainless header, 20mm carb. I made an adapter to use a Triumph velocity stack/filter. The guy I bought it from built it for a small funkart, but after he tried it out,he was afaid to turn the kids loose on it.It stiil has the internal governor parts, but has a spring on the arm to hold tension to keep it from coming apart inside.The tire on the rear wheel is new, and I have the front wheel with a new tire to go on too. The wheels fenders and forks are from a Bird Nighthawk. Thanks Motra for a good deal on tires wheels and fenders.:thumbsup: I welded up the bolt holes on the fenders, and they came out good. I need to get a taller more MX style handlebars. I'm going to use a 2 speed. If I don't like it I'll mount a 20 series torque converter setup with the driven on the jackshaft if there's room. It may need raised jackshaft mounts for that. I hope to have it blasted and primed this week, and painted next week. The fun is just beginning.:thumbsup: This one will be grouped in with a couple others to start a line I call the Junk Collector Series.:wink: :biggrin:
