I hope this helps someone, I was at Oreilly Auto parts getting some wiring, and ran across these exhaust manifold studs. They are M8-1.25x56mm studs. I knew the side cover bolts were M8, but was not sure if the 56mm would be too long, so I purchased them to try. I paid $7.99 for 10 studs/nuts. The fit is spot on, and I do not see any reason why these would not work with any clutch, the stud sticks out 10.6mm from the side cover. I installed these on a Honda GX160 block.
