Hi all. I've run into a problem that I cant quite figure out. Sorry for the long read but I hope you can help.
I've recently ported my engine head and I have milled the head by .015" and no doubt the flow has increased, but I seem to be getting the results of an extremely rich jet, but its only the stock jet size... I have even sized down from like .038" because it was only running slightly rich then. The spark plug comes out dark black and the engine used to top me out at 48mph but now I struggle to top 30mph. The engine sputters and the clutch jerks and engages/disengages because the engine isn't keeping a stable rpm. I can only get it to about 20mph before it gets rough.
The engine should be maxxing at around 6400 based on my speed and gearing. Heres all of my engine info:
clone GX200
flat top piston
arc rod
stock head milled .015" and ported
UNI filter
staight pipe
6 degree advance stock flywheel
clone GX200
flat top piston
arc rod
UNI filter
staight pipe
