I'll need to get pics and a video posted soon. The seat was finished within 24 hrs, will get a pic up tomorrow. I got the clutch turned around and lined up perfectly with rear sprocket, so despite the absence of footpegs or a brake, I just had to take it up the street a few times,
ut:, moderate load, to break in the engine and the clutch. Clutch engages at 4100 rpm so it sounds like you're not going anywhere at first, then ya start movin out and the front end comes up at about 20mph and carries as far as you want it to at about 3/8 throttle. Once ya get the front end back down and gas it again it starts really pullin hard! Im gonna need a wheelie bar...brakes...and some new boots! And a drive chain idler, I see scratches on the frame rail! Hmmm, lets use a rollerskate wheel for that.
Im pretty happy with its first ride! :thumbsup: There are a couple drawbacks, weight distribution favors the right side a bit, probably due to the massive flywheel. I cant move the engine over any more to the left so it is what it is. It doesnt corner too bad with the 6" slick, but could handle better, compared to the punch this thing has ya dont really notice...you adjust to it.
The 4.1 to 1 ratio seems to be right between what Id want for a 1/4 mile gear and an 1/8 mile gear....3.6 to 1 should work well in the quarter, 4.6 to 1 for 1/8...we'll see! First lets do the brake! :wink:
