I stripped out the set screw hole on my clutch, the one that screws into the key, the other set screw is in nice and tight, is this set screw that important, once I screw in the bolt at the end of the shaft, the clutch won't be able to slide off. Do I need to re-tap the set screw hole or do you think I can run it with one set screw? Thanks!:laugh:
