Gx200 internals in a Gx160 block??
The Gx160 crank rod and piston combo height is 129.4 mm
The Gx200 crank rod and piston combo height is 133.9 mm, 4.5 mm more than the Gx160 or have the stroke difference between the two motors.
The stock Gx160 and 200 have the same rods and pistons.
Your crank, rod and piston combo is 134.569 mm, 5.169 mm (0.203'') positive deck in your Gx160 block (assuming a zero deck dimension).
A stock rod on your combo will be 127.156 mm, 2.244 mm (0.088'') negative deck, same block.
Your crank rod and piston combo is 0.026'' longer than a stock Gx200
For your combo to work you need ether a 160 crank or a 200 block.
