Hi Folks;
Finally finished my Super Bronc VT1012 but I think I am having TAV problems.
I bought the Bronc with an 8 hp Tecumseh. It had the 60 tooth sprocket on the rear. I ran it down the alley and I remember thinking "geez, this thing is SLOW!" Well, it will be better when I put the 10 HP Tecumseh on it.
The rebuild is now complete. I have a brand new Tecumseh 10 hp and I stepped down to a 40 tooth sprocket on the rear. The engine develops around 3100 RPM at full throttle. It has the original TAV on it from the original Bronc kit. It only does around 22 mph!
During the rebuild, I took apart the TAV, cleaned it up good, greased where necessary, cleaned and polished the belt surfaces, and installed a new belt. This thing should be doing dang near 50 mph!
The reason I am beginning to think TAV problems is that it is the original one and it was slow with the 8hp before I began the rebuild.
Any thoughts from you experts as to where I should start to troubleshoot?
