I have a firehawk with 19 in tires a 10 tooth clutch and a 72 tooth rear sprocket. The top speed it 43 mph and it revs about 5500 rpms. If I were to get a tav2 would it be able to allow the motor to rev up to 5500 rpms with a 7.2:1 ratio? Or would it rev up about half way at 4000 ish rpms? Never seen a clear answer for this . What is the top speed on your Baja minibike with a tav2, and what is your gear ratio and tire size? Thanks for the replies
