I would say no.. The sheet metal has been transfered.. Ya may get lucky and find a lighting coil and lighted wheel under the JD sheet metal, but I sincerely doubt it.. The 110 volt starter means no battery to charge.. so no lighting stuff.. However, some of those big expensive JD snowblowers DO have a headlight on em.. The engine is parted together, so God knows what got used and what didn't.. :shrug:
Plus, if the sheet metal is swapped out, you don't even know if it is an H70.. It's either a 60 or 70 I'd say, being you can't see the diamond on the block..
It's got an aluminum Tecumseh tag on it.. Thats pretty cool. :laugh:
