I need a Tecumseh lighted flywheel for a HS 40 or 50 to fit a non points motor. Not sure if they are different between the years, mine has the squarish shroud with a bump out around the pull starter if that helps. Can get the numbers off the motor also if needed.
Thanks, Owen
