I have an old Tecumseh ohh60 that is on a mini bike and has not been ran in a long time. I drained the oil put in fresh put gas in it and fired right up. Kinda seemed like it was bogging and surging but ran good sometimes. Shut it off and the entire tank of gas ended up on the ground since it was leaking out of the air filter side. I pulled the bowl off and took the float off and it must have a hole in the float because there is gas in there. Anyway, should I replace just the float, the complete carb (most likely with a cheap $15 one on ebay), or the whole motor (most likely with a hf predator 212) since I have read that these motors are pretty much junk. Thanks for any input
