As part of the teardown of my Terra Trailtopper, I discovered there are two steel/rubber bushings inside of the trailing arm pivot with a 10MM rod holding the trailing arm to the bike.
The bushings (there are two) are comprised of a 10MM ID steel sleeve and a 20MM OD rubber bushing.
Has anyone seen a setup like this? Did other bikes like Rupp ever utilize anything like this?
I have had no luck finding anything on the internet for replacement pieces. If anyone can point me in a direction, that would be great. Otherwise, I will fabricate replacements.
Thanks for any help!
