That 70 mm (2.75590551181102 inches ) should do wonders for compression ratio; Currently .009 is the thinnest gasket available; Works well with a thin shot of coppercoat,have not had one leak on 30+ Engines
Hardy har, loads of laughs, your a riot! The one that OldMiniBikes sells is .010 thick for a 70mm bore. BTW you being such a super genius and all. What did you think about the Zero gasket mentioned above?:wink:
Stock Honda 200 is .010 Thin metal. So are some clones. Champion 6.5 Clone has .010 TThin metal. HF clones have the thicker fiber metal. Maybe plays into not wanting to copy exactly.
I meant the aftermarket suplier link.
They make aftermarket gaskets in Cambodia ( not sure of the top off my head now about country of origin)
Any material or thickness.
I have som eof their Petter aftermarket gaskets and I know some kart people buy thin copper sheet and fire riing gaskets from them.
They will make as many as you like and the prices are reasonanble
