Thanks, I ended up getting it.
The rust is only surface so painting the frame should be easy. Trying to see if I can get the motor unstuck should be fun.
Need to by some parts for the Jackshaft Assembly as you can see it's missing some. Not ready to drop $$ on a TAV.
If you mean the chain tensioner on the jackshaft, you don't really need it. Replace the small chain complete with a new masterlink.
Then put a small section of rubber fuel line over the bolt at the top, this will keep the chain from digging through the bolt and adds some slack take up.
I have a beater Baja that has had the same jackshaft chain on it for 4 years now and it never jumped off, that is the beauty of the big links compared to wimpy #35 chain.
To hold down the seat (since I know your seat bolt mounts are torn out of the base of the seat), Feed zip strips under the base of the seat near the rear mount and then under the frame, pull them up tight and NEVER try to lift the bike by the seat and it will stay on just fine.
Try Green Slime for the tires, get the jumbo size bottle, worth a try.
Anyway, good luck and keep us posted.
HTH
Later,
Keith
