Torque converter engaging in Idle
panchothedog
In the 2nd picture ( the one from the rear tire ) your clutches are clearly not lined up correctly. Your driver needs to be moved out about 3/16 ". Or move the driven in. Looks like you have room to do that. Pretty big gap between the chain and the backside of the driven. The two inner sheave faces MUST be lined up almost perfectly. Use a straight edge and washers to get it right. Most of the kart supply shops sell special shim washer kits, much thinner than common hardware store washers.
