Hello all I'm back again in need of guidance. Ok so got a new dirt kart and having trouble with the power plant. Here's the specifics: standard bore clone w/ governor out, billet rod and flywheel, honda flat top piston, ported and milled head w/ 27mm int. 24mm exh. , 1/4 pushrods, billet lifters, long single stage pipe and a gx390 carb. I am running the stock cam w/ 1.3 lifters and 18lb springs. Here is my problem, motor starts fairly easily, idles fine, and screams at W.O.T., it's the in between I can't get right. You have to baby the throttle open or it falls on it's face or even dies. You can't even remotely stomp on it. Is this jetting or perhaps timing?? I currently have the timing at stock and the 390 clone carb as out of the box. Any help GREATLY appreciated guys!!!!:thumbsup:
