I had a tuning problem with my bike. I put a temporary engine on my mtd trail flight so I could get it running while I re built and modified the original hs40. I put what I thought to be a good running carburetor on the engine. but It wouldn't run steady It would run for a bit and die then run a bit more and die. I cleaned the carb several times trying to solve the issue just to realize it was still getting dirt in the bowl. so I pulled the carb off and noticed my fuel filter was abnormally bent. the fuel filter had bent and broken internally due to having too short of a line between it and the carb and it was allowing dirt threw the filter. I never even thought it could have been my brand new filter. I spent an entire afternoon trying to fix that carb and it was the freaking filter.
you guys ever have issues like this one where you spent allot of time hunting down a tuning or mechanical problem and the answer was totally unexpected or ridiculously simple.? if so lets hear them.
